| Turbodiesel DV4TD |
Fuel:
| DIESEL FUEL |
Cover for luggage:
| MAGAZINE SHELF |
Protecting the front seat:
| CABIN WITHOUT PROTECTIVE PANEL |
| DV4TD TURBO DIESEL |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE ALUMINIUM |
| DIESEL FUEL |
SPEED SENSOR SIGNAL:
| MULTIFUNCTIONAL ACTIVE SENSOR |
| EV/DV |
CATALYTIC CONVERTER:
| 2-COMPONENT CATALYSER 50 PPM LOWER PLATE |
COOLING MOTOR:
| RADIATEUR EP:27 - 16 DM2 ALU BRASE SS MEC |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| "EGR" EXHAUST GAS RECYCLING |
| WITHOUT PARTICLE FILTER |
| 1 AERO 2-SPEED 90W FAN |
FUEL VAPOUR RETRIEVAL:
| WITHOUT PETROL VAPOUR RECUPERATION |
| SIEMENS ASSEMBLY |
HYBRID DRIVE TRAIN:
| WITHOUT ALTERNATOR-STARTER |
TANK FILTER:
| CITHOUT RESERVOIR FILTER |
STOP AND START:
| WITHOUT STOP AND START |
| BVM5 |
| BVM MA5 / O |
| REAR AXLE HYPOID GEARSET 17 X 61 |
SPEEDOMETER DRIVE:
| CT 21 X NO |
| 14 INCH STEEL WHEEL |
DIFFERENTIAL (GEARBOX):
| DIFFERENTIAL 77 |
RIM/TYRE SIZE:
| 14 INCH TYRE FITMENT |
| 175X65X14 T TYRES |
WHEELS FITTED:
| 5,5" RIM ROAD WHEELS |
| STEEL WHEELS |
| MA |
ABS:
| WITH ABS BRAKES |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 23.5 |
| FRONT ANTI-ROLL BAR DIAM 19 |
BRAKE TYPE:
| NON-VENTILATED FRONT DISCS/REAR DRUMS |
| NORMAL SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT:
| ABS TEVES MK70 |
ELECTRIC STEERING:
| 60 AMPERES ELECTRIC STEERING |
PEDAL BRACKET (TYPE):
| PEDAL STANDARD |
TOWBAR:
| WITHOUT TOWBAR |
AERIAL:
| SHORT ROOF AERIAL |
OPENING ROOF (APPEARANCE):
| WITHOUT SUN ROOF |
REAR SPOILER:
| ASSEMBLY WITHOUT REAR SPOILER |
| BODY COLOUR LATERAL PROTECTORS |
| 14 INCH 14-SPOKE CONDOR STYLE |
UNDERBODY SHIELD:
| PLASTIC PROTECTIO + FOAM UNDER ENGINE |
| W/O ENGINE UNDERSHELDING |
| EXT MIRROR MANUAL-FOLD BACK |
EXHAUST TAILPIPE TRIM:
| W/O EXHAUST OUTLET EMBELLISHER |
ENGINE BAY SOUNDPROOFING:
| BONNET SOUNDPROOFING |
| INTERMITTENT WINDSCREEN WIPER+ADJUST |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
REAR TAILGATE GLASS:
| FIXED TAILGATE WINDOW |
OUTSIDE TEMPERATURE SENSOR:
| WITH EXTERIOR TEMPERATURE SENSOR |
BUMPER:
| BODY COLOUR / BLACK APPEARANCE FR+RR BUMPER |
| NO FRONT FOG LIGHTS |
| DRIVER’S DOOR MIRROR ELECTRIC CONTROL |
| PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL |
| STEEL WHEEL + STANDARD TYRE |
| UNCOLOURED DOOR HANDLES + DOOR MIRRORS |
SPARE WHEEL MOUNTING:
| STANDARD SPARE-WHEEL CARRIER |
| FIXED ROOF |
| NON ATHERM WINDSCREEN+TOUGH SIDE AND RR WINDOWS |
| WARP AND WEFT TRIO + OMNI "2S" |
REAR HEAD RESTRAINT:
| WITHOUT REAR HEADREST |
FRONT HEAD RESTRAINT:
| FRONT HEADREST ADJUSTABLE |
| RR BENCH MONOBLOCK CUSHION SEPA FOLDING BACK |
LUGGAGE COVER:
| SHELF |
| REAR INERTIA-REEL SAFETY BELT |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITH ALARM |
| TEMPERATE COUNTRIES |
| GRADUATION KMS/H |
GRAB HANDLES:
| HANDLE FR PASS + HOOK |
RADIO EQUIPMENT:
| FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
| LEFT HAND DRIVE |
REMOTE CONTROL:
| REMOTE CONTROL ASSEMBLY |
| STANDARD FASCIA PANEL + SOLID COLOUR CONTROL PANEL |
MISC. INT. LAMPS:
| W/O MAP READING LAMP |
| DIGITAL INSTRUMENT PANEL NEUTRAL FRONT PANEL |
| 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| REMOTE RADIO CONTROL |
POLLEN FILTER:
| WITH POLLEN FILTER |
| WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
DRIVER SEAT CONTROL:
| MEMORY CTRL DRIVERS FRONT SEAT |
DRIVER SEAT ADJUSTMENT:
| RECLINING DRIVER’S SEAT BACK |
FRONT SEAT ARMREST:
| ASSEMBLY WITHOUT FRONT ELBOW REST |
| WITHOUT COMPACT DISC |
| WITHOUT NAVIGATION SYSTEM |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| STD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW |
| DISPAY (RADIO+CLOCK+AND OR T°, CD) WITHOUT MEMORY |
CLOCK:
| NUMERIC CLOCK |
COURTESY MIRROR:
| DRIV OCCULT+PASS OCCULT W/O LIGHT |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
FITTING REAR HEAD RESTRAINT:
| WITHOUT REAR HEAD-REST |
| NON HEATED SEAT |
| WITHOUT FRONT SIDE AIRBAG |
ON-BOARD COMPUTER:
| COMPUTER |
| NON HEATED DOOR MIRROR |
| INT DOOR HANDLE GREY LION |
FRONT SEAT GUARD:
| WITHOUT CAB PROTECTION PANEL |
STORAGE (DRIVING POSITION):
| LOWER STORAGE COMPARTMENT WITHOUT LOCK |
| "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM |
| SINGLE AIR CONDITIONING |
| WITHOUT SPEED CONTROL |
DRIVER’S SEAT HEIGHT CONTROL:
| PARALLEL DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
STORAGE (OTHERS):
| W/O OTHER SETTING BOXES |
DRIVER AIRBAG:
| DRIVERS AIR BAG |
LOAD SPACE STORAGE:
| W/O BOOT TIDY |
EXTERIOR TEMPERATURE (SCALE):
| EXT TEMP INDICATOR CELSIUS |
OBSTACLE DETECTION SYSTEM:
| WITHOUT OBSTACLE DETECTOR |
| G/LEVER KNOB LEATHER CHROME INSERT |
| SIMPLE CENTRAL LOCKING |
| RUBBER STEERING WHEEL |
| ALTERNATOR 150 AMP |
| BATTERY L2 400 |
| STARTER MOTOR CL 4 |
| WITHOUT PARTICULAR LIGHT |
CEN. LOCKING REM CONTROL FREQUENCY:
| LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY CAN CAN |
| FURIO 3 |
| NORMAL ATMOSPHERE |
RADIO HEADPHONE SOCKET:
| WITH ACCESSORIES SOCKET |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
EMERGENCY EQUIPMENT:
| W/O HELP EQUIPMENT |
SPEED MONITORING:
| PROGRAMMED OVERSPEED WARNING |
EMERGENCY WARNING TRIANGLE:
| WITHOUT WARNING TRIANGLE |
