Prosze o sprwadzenie tego auta Focus WF0KXXGCBKBU64871
2020/05/02 14:49 #89637
heli
Opcje wyposażenia:
Engine Cover - Under Hood Engine Cover - Under Hood
Passengers Air Bag With Passenger Air Bag
Front Fog Lamp Type With Front Fog Lamps
Maplight Front And Rear Lamp LED
Suspension Types With Standard Suspension
Drivers Seat Adjustment Type With Driver 4 Way Mnl.Seat Adjuster
Door Mirror Finish With Body Coloured Exterior Mirror
Door Locking Systems With Central Locking System
Headlamp Levelling Type With Manual Headlamp Levelling
Speedometer Types With KMH Speedometer
Marketing Levels Marketing Level 1
Passenger Seat Adjustment Type With Pass 2 Way Manual Seat Adjust
Door Remote Control Unit With Door Entry Remote Control Unit
Overhead Console Mini Overhead Cnsl W/Sunglass Bin
Fuel Tank Lock Non Locking Capless Fuel Fill
Front Headrests With Front 2 Way Headrest
Fresh Air Heater With Recirculating Heater
Wheel Lug Nuts Non Locking Lug Nuts
Side Air Bag - Passenger Side With Side Air Bag - Passenger Side
Voice Activated Modules Voice Activated Module - French
Rear Headrest Type With Integrated Rear Headrest
17 Inch Tyres 215/50 17 W Rated BSW Tyre
High Mounted Stop Lamp With High Mounted Stop Lamp
Shutters - Radiator With Kysor Radiator Shutter
Rear Passenger Door Rear Passenger Door
Batteries Standard Duty Battery
Headlamps - Design With Halogen Headlamp
Rear Bumper Rear Bumper Body Coloured Plastic
Door Frame Moulding Type With Bright Door Frame Moulding
Front Window Operation Power Front Windows One Touch Up/Do
Tripminder With Trip Computer
Front Floor Mat Style With Velour Front Floor Mats
Heated Windscreen With Heated Windscreen
Brake Calipers And Pads Standard Duty Fr/Rr Calp And Pads
Exterior Mirror Dual Dual Pwr/Heat/Fold/Pud Lamp/Signal
Rear Floor Mats Style With Velour Rear Floor Mats
Headrestraint - Rear Center With Rear Center Head Restraint
Rear Shock Absorber Type With Standard Rear Shock Absorbers
Door Handle - Exterior Body Coloured Exterior Door Handle
Load Floor Covering With Load Floor Carpet
Air Curtain Restraint(RH/LH) Air Curtain Restrnt LH
Tailgate Release With Remote Controlled Tailgate Release
Front Seat Belt Mounting With Manual Adjust Frt.S.Belt Mount
Steering Column Types With Manual Tilt/Slide Stg Column
Rear Seat Belts Retractable Rear Seat Belt-3Point
Air Curtains (Use CP1 Family) Air Curtain Restrnt RH
City Safety Low Speed Safety System
Rear Tyre Tread Pattern With Standard Tyre Tread - Rear
Foot Pedal Design Standard Foot Pedal Pad Design
Front Tyre Tread Pattern With Standard Tyre Tread - Front
Load Compartment Lamp With Load Compartment Lamp
Power Point Rear With Power Point Plug - Rear
Isofix Hard Point Attachment With Isofix Hard Point Attachment
Transmission Gear Sets 3.58/1.95/1.19/0.84/0.94/0.79
Speed Sign Recognition Speed Sign Recognition
Instrumentation Type Conventional Instruments - Level 3
Tail Lamps Tail lamps - LED Rear
Adjustable Foot Pedals With Fixed Foot Pedals
Seatbelt Anchorage 3 Part Seat Belt- European Regultn
Smokers Package With Smokers Package
Centre Console Console - With Closed Bin
Side Air Bag - Drivers Side With Side Air Bag - Drivers Side
Drivers Air Bag With Driver Air Bag
LH Arm Rest With LH Front Door Armrest
Spare Wheel Type Spare Wheel - Mini Steel
Fog Lamp Bezel With Chrome Fog Lamp Bezel
Single Note Electric Horn Dual Note Electric Horn
Exhaust Systems Strt Sngl Vsbl Pipe One Sd Sngl Muf
Steering Wheel Radio Controls With Steering Wheel Radio Controls
Exterior Tailgate Handle Body Coloured Tailgate Handle
Corporate Badge Ford Corporate Badge
Drv St Back Mtd Map Pocket With Driver Seat Back Map Pocket
Front Spring Load Class Front Spring Load Class-R
Rear Window Operation Power Rear Window One Shot Up/Down
Outer Rocker Panel Moulding Colour Rocker Panel Moulding -Cladding C/K
Exterior Paint Pack Exterior Paint - Solid
Lumbar Seat Support Driver Seat With Drivers Manual Lumbar Support
Starter Motor Type Standard Electric Starter Motor
Rear Brake Type With Rear Disc Brakes
In Car Entertainment ICE- Mid Audio (1C) W/Connectivity
Pass Seat Back Mtd Map Pocket Passenger Seat Back Map Pocket
Lane Keeping Aid Lane Keeping Aid
Blind Spot Information System BIS W/Radar-BLIS/CAN LED
Steering Types With Electric Power Steering
Plant Build Requirements Saarlouis Plant Built
Front Heated Washer Jets With Heated Washer Jet
Blue Tooth Interface Connect BT/VC Phone Interface + USB Connect
RH Arm Rest With RH Front Door Armrest
Header Mounted Map Reading Lamps Fr Individual and Rr Map Lights
Engine Immobilizers With Engine Immobilizr - Securilock
Gearshift Knob With Leather Gear Shift Knob
Navigation Data Navigation Data - Western Europe
General Stowage Box With General Stowage Box
Radio Speakers With 6 Speakers
Parking Brake - Function Type Mechanical Hand Operated Park Brake
Rear Seat Centre Armrest Rear Centre Armrest With Stowage
Rear Spring Load Class Rear Spring Load Class-Q
Fuel Filler Door Lock Capless Fuel Filler Without Lock
Auto Headlamps With Auto Headlamps
Cold Start Type Cold Start -29 Deg C
Temperature Zones For Normal Temperature Zones
Seat Belt Warning Type With Drvr/Passngr Seat Belt Minder
Rear View Mirror Type With Electrochromic R/View Mirror
Marketing Flex Prep Pack Leather Pack Syracuse
Rear Towing Hooks With Rear Towing Hooks
Glove Box Lamp With Glove Box Illumination
Windscreen Wash/Wipe With Automatic Windscreen Wiper
Module Configuration Outside Air Temperature Present
Sunvisors - Driver With Illuminated Sunvisor - Drivers
Sunvisors - Passenger With Illuminated Sunvisor-Passenger
Front Towing Hooks With Front Towing Hook
Child Proof Locks With Child Proof Safety Lock
Speed Control Speed Control And ASLD
Tether Anchorage Style 1 Tether Anchorage Restraint
Interior Cab Assist Handle - Driver Rear Coat Hook
Driver Impairment Monitor Driver Impairment Monitor
Global Closing With Auto Closing Windows
Drivers Recliner Seat With Driver Seat Recliner - Rotary
Rear Spoiler Type With Large Single Wing Rear Spoiler
Headlamp Bezels With Black Headlamp Bezels
Instrument Cluster - Rheostat With Instrument Cluster - Rheostat
Tinted Glass With Privacy Glass
Fuel Capability Type With Diesel Fuel Capability
Rear Window Wash/Wipe With Int. Rear Window Wiper/Washer
Ignition Key Type Ignition Key Combination Pack 1
Interior Door Handle Type With Aluminum Interior Door Handles
Grille - Lower Lower Grille - Hgh Gls W/Chrm Smile
Hill Launch Assist With Hill Launch Assist
Interior Feature Colour Int Feat Colour - Charcoal Black
Padded Dash With Padded Dash
Load Compartment Cover With Load Area Cover
Interior Environment Colour Int Environment Clr-Charcoal Black
Rear Fog Lamps With Single Rear Fog Lamp
Accessory USB Unit Accessory Media Hub 1XUSB
Headlamp Control With Auto High Lamp Headlamp
Integrated Control Panel ICP Nav
Rear Side Air Bag
Anti-Lock Brakes Brakes-HLA/ESP/TC/ABS
Footwell Lights With Footwell Lights
Wheel Size/Style - 17 7J X 17 Style 5 Alloy Wheel
Steering Wheel Type 4 Spoke Leather Steering Wheel
Auxiliary Heater With Supplemental Air Heater
Air Purifier Pollen/Carbon Filter
Folding Rear Seat Type With 60:40 Split - Folding Rr Seat
Grille - Upper Grille - Upper Blk Msh/Chrome Surnd
Message Centre With Message Centre
Passenger Recliner Seat With Passenger Seat Recliner-Rotary
Interior Light Group Interior Lighting-Ambient LED
Headlinings Deluxe Headliner
Liftgate With Manual Liftgate
Rear Seat Cushion Type With Two Piece Rear Seat Cushion
ICE Feature Pack With ICE Feature Pack 11
Front Seat Type With High Back Front Seats
Tyre Spare Limited Service Mini Spare Tyre
Front Door Sill Protection Front Door Scuff Plates - Ford Oval
Keyless Entry System Keyless Entry/Start - Passive
Tailgate Badges LESS TAILGATE BADGES
Front Bumper Front Bumper - Painted Body Colour
Multi Function Display MFD Nav Low TFT Screen
2020/05/03 10:34 #89649
Inspektor
zanim kupi niech zapozna się z kosztami i żywotnością automatów forda
Powershift 6DCT450
prawy przedni błotnik i zderzak przedni jakoś mi się rzucają w oczy
Szczegóły
Oferta od
Firmy
Kategoria
Osobowe
Marka pojazdu
Ford
Model pojazdu
Focus
Wersja
Mk3 (2010-)
Generacja
Mk3 (2010-)
Rok produkcji
2011
Przebieg
138 000 km
Pojemność skokowa
1 997 cm3
Rodzaj paliwa
Diesel
Moc
140 KM
Skrzynia biegów
Automatyczna
Napęd
Na przednie koła
Typ
Kompakt
Liczba drzwi
5
Liczba miejsc
5
Kolor
Biały
Akryl (niemetalizowany)
Tak
VAT marża
Tak
Kraj pochodzenia
Francja
Pierwsza rejestracja
30/11/2011
Bezwypadkowy
Tak
Serwisowany w ASO
Tak
Stan
Używane
VIN
wf0kxxgcbkbu65672
2020/05/03 15:55 #89672
gaco12
Masz racje on był tam przerysowany i naprawiany.
A pisze cos o przebiegu serwisie wypadkowosci ?
