nie ten dzial.. szukasz histori i rozkodowania czyli ocena auta dzial. Przenosze
| KMHET41VP6A218076 |
| South korea |
| A-San |
| HYUNDAI |
| NF |
| 2006 |
| sedan |
| 2500 |
| 218076 |
| Sonata NF (-SEP 2006) (2004-) [EUR3K0PA04] |
CLASS:
| MIDDLE GRADE |
BODY:
| 4 DR SEDAN |
ENGINE TYPE:
| 2000 CC |
| T/C INTER COOLER |
| 4 SPEED AT 2WD |
| KMHET41VP6A218076 |
| 18.03.2006 |
AREA CODE:
| C51 - EUROPE |
| C04 - DENMARK |
COLOR CODE INTERNAL FINISHES:
| CH |
CODE Exterior:
| B7 |
Y0C0:
| NF |
Y0C4:
| NF (TCI) |
0720:
| VGT ENGINE |
0950:
| DIESEL |
2839:
| EMISSION EC 2005 |
2924:
| ENGINE COVER |
371B:
| BATTERY-90AH(MF) |
437R:
| SHIFT KNOB CAP-PAINT |
52BV:
| TIRE- 215/60 R 16 |
5274:
| HANKOOK |
5276:
| KUMHO |
53W2:
| WHL-6.5J *16(STEEL) |
531H:
| FULL CAP-14" |
5462:
| GAS |
5464:
| GAS SHOCK ABSORBER-RR |
561D:
| PLASTIC |
5613:
| STRG-NORMAL POWER |
569H:
| AIR BAG(SIDE-CURTAIN A/BAG) |
569Z:
| CUT OFF SWITCH |
5691:
| A/BAG(D/S) |
5692:
| A/BAG(P/S) |
5695:
| AIR BAG-SIDE |
5815:
| BRAKE-FR(DISC 16 INCH) |
5835:
5851:
| BRAKE BOOSTER |
5973:
| CR-COATING |
6501:
8136:
| IMPACT SEN'G AUTO DR UNLOCK |
8197:
| KEYLESS(433.9MHZ) |
8222:
| MLDG-DR(BLACK) |
823E:
| DR A/REST(PVC) |
8233:
| TRIM-DR(DLX TYPE-CLOTH) |
8241:
| TNTD |
8267:
| BODY COLOR |
842C:
| COVERG-FLR(T/C PILE-DLX) |
8450:
| ASH TRAY-WITH ILLUM. |
846C:
| CONSOLE-DLX(CLOTH) |
847K:
| SOFT PAINT |
847Y:
| CENTER TRAY(WithTRAY) |
8512:
| MIRROR-I/S(DAY & NIGHT) |
852C:
| MRR-VANITY(ILL) D/S |
852K:
| SUNVISOR-EXTENSION |
8526:
| MRR-VANITY(S/V NON GLA) P/S |
8527:
| SUNVISOR-DUAL(CLOTH) |
8531:
| CLOTH |
8584:
| DR SCUFF-STD |
8620:
| TNTD & S/BAND |
8638:
| RAD. GRILLE-A TYPE |
8712:
| TNTD & HTD |
8718:
| HEATED |
8742:
| MRR-O/SIDE(BODY COLOR) |
875D:
| MRR-PA'S ELEC:HTR CONV |
8769:
| MRR-DR CONVEX(ELEC HTR) |
8770:
| MLDG |
8801:
| CLOTH |
8816:
| B/POCKET |
8817:
| B/PANEL |
888D:
| S/BELT DRIVE PRETENSION |
888F:
| SEAT BELT-FR DR'S LOAD LIMITER |
888J:
| SEAT BELT-FR DR'S BUCKLE P/T |
8888:
| SEAT BELT-FR DR'S(ELR 3PT) |
889D:
| S/BELT PASS. PRETENSION |
889F:
| SEAT BELT-FR PA'S LOAD LIMITER |
889J:
| SEAT BELT-FR PA'S BUCKLE P/T |
8898:
| SEAT BELT-FR PA'S(ELR 3PT) |
8903:
| RR-SPLIT FOLD'G |
8942:
| A/REST Without PACK TRAY |
8958:
| H/R-RR(UP/DOWN & TILT,LH) |
8959:
| H/R-RR(UP/DOWN & TILT,RH) |
8961:
| H/R-RR(UP/DOWN & TILT,CTR) |
898C:
| SEAT BELT-RR CTR(ELR) |
8987:
| SEAT ANCHORAGE-CHILD |
9211:
| HLLD |
9212:
| DRL |
9215:
| BULB-12V P43T(H4 HALOGEN) |
9231:
| REPEATER-SIDE |
9242:
| LAMP-FOG(RR) |
9263:
| LAMP-GLOVE BOX |
9275:
| LAMP-HMS |
9284:
| LAMP-ROOM(FR) |
9403:
| KMH |
9407:
| LAMP-S/BELT REMINDER WARN'G |
9495:
9542:
| IMMOBILIZER |
9544:
| ELEC TIME/ALRAM CONTROL SYSTEM |
96C1:
| COMPONENT-1 DIN |
96SE:
| SPKR-FR |
9607:
| ANTENNA-GLASS(RADIO) |
9619:
| AM9K/FM50K |
9631:
| AUDIO BLANK'G COVER-GERMANY |
970A:
| TEMPERATURE UNIT 'C' |
9713:
| AIR FILTER |
9719:
| AUXILIARY HEATER-FUEL FIRED |
9728:
| RTY+P/BTN TYPE |
9836:
| WASHER FLUID LEVEL SENSOR |
W20:
| THE FROZEN ZONE |
5896:
| ESP(ELECTRONIC STABILITY PRM) |
8133:
| ANTI THEFT SYSTEM-IGNITION KEY |
864C:
| MUD GUARD-RR(Without LETTER) |
8647:
| MUD GUARD-FRT(Without LETTER) |
8876:
| ACTIVE HEAD RESTRAINT |
9341:
| A.C.C |
9760:
| AIR CON |
9761:
| AIR CON-MANUAL (HCC) |
Numer VIN: KMHET41VP6A218076
Marka pojazdu: Hyundai
Model pojazdu: Sonata
Data badania technicznego: 03-09-2012
Numer rejestracyjny: YE26424
Odnotowany przebieg: 166000 km
Data badania technicznego: 20-08-2012
Odnotowany przebieg: 165000 km
Data badania technicznego: 10-08-2010
Odnotowany przebieg: 116000 km
na ostatnim przegladzie auto bylo sprawne. Dunskie przeglady sa rygorystyczne. Zaliczyl ok. Nie szukaj czy robili rozrzad tylko go wymien o ile jest na pasku oczywiscie bo tego nie wiem. Nie znam sie na tych autach. Mozesz zadzwonic do aso z pytaniem czy maja cos w bazie. Ja mam tylko przebieg.
