WT 3:
| TEMPERATE ZONE |
0091A4:
| ENGINE PACKAGE - CVVT ENG |
0099A2:
| FACE LIFT MODEL - 2'ND F/LIFT |
2841B3:
2843A2:
| EVAP. GAS CONTROL - EURO-3 |
2861B3:
2921A2:
| ENGINE COVER - SEMI |
3111B5:
| FUEL TANK-CAPACITY - 55 LITER |
3711A9:
3921A1:
4371A3:
| MT KNOB - LEATHER WRAPPED |
529AB1:
| TIRE PRESSURE LABEL - EUROPE |
529TB1:
| TOOL SET & JACK LABEL - INDIA |
5294A1:
| TIRE SOURCE - HAN KOOK |
5297C1:
| TEMPORARY - STEEL WHEEL & TIRE |
5413A2:
| S/ABSORBER SOURCE - SACHS |
5511A1:
| RR SUSP TYPE - DUAL LINK |
5531A2:
| TUN'G MODE - HARD SUSPENSION |
5611B3:
| 3-SPOKE - LEATHER |
5631A2:
| STEER'G COLUMN-MANUAL UPR TILT |
5691A3:
| DRIVER SIDE - DEPOWERED |
5692A3:
5693A1:
5711A2:
| HPS(HYDRAULIC POWER STRG) |
5811A4:
| FR BRAKE - DISC-15 INCH |
5812A8:
| RR BRAKE - DISC-15 INCH |
| ABS (ANTI LOCK BRK SYS) |
5911B1:
| TANDEM BOOSTER - 8+9 INCH |
811AA1:
| HOOD INSULATOR |
8112A2:
8122A2:
8123A3:
| TRUNK LID RELEASE TYPE - ELECTRIC |
8131A1:
| CENTRAL DR LOCK/UNLOCK - DR'S CONTROL |
8152A3:
8153A1:
| FUEL FILLER DR FINISH'G - BODY COLOR |
8175A2:
| TAIL GATE RELEASE TYPE - ELECTRIC |
| KEYLESS ENTRY-B/ALARM |
8195A1:
| DR FRAME MLDG - BLACK |
8231B2:
| FORMED TYPE - DLX |
8233G1:
8235A1:
| MAP POCKET FINISH'G - Without T/C PILE |
8236A1:
| ARM REST COVER'G - PVC |
| FR DR GLASS - TINTED |
834AA1:
| AUTO DOWN |
8341A1:
| POWER WINDOW(FR) |
84F3A1:
| AMBIENT TEMP DISPLAY |
8421E1:
| T/C PILE - CARPET_STD |
8441A3:
| FR - ASH TRAY With ILLUM |
8445A2:
| CIGAR LIGHTER - With ILLUM |
8451A1:
| Without LOCK |
846BA1:
846FA3:
| STORAGE BOX - WithRUBBER PAD |
8461B1:
| DLX - PVC |
8475A1:
| CUP HOLDER - SEPARATE |
8511B1:
| DAY/NIGHT TYPE |
852GA2:
| VANITY MIRROR - NON GLASS TYPE |
8521A3:
| MATERIAL - CLOTH(STD) |
8522A2:
8523A3:
853JA1:
| RR - 1 EA |
8531A3:
857CA1:
| TRUNK STORAGE BOX |
8571C1:
| LUGGAGE SIDE - WithPAPER |
8572A3:
| RR - WALL PAPER |
8573A3:
| FLOOR - N/PUNCH |
| LUGGAGE NET HOOK |
8579A1:
| LUGGAGE NET |
858RA4:
| DR SCUFF - PLASTIC TYPE |
8591B1:
| COVER'G SHELF TRIM - WALL PAPER |
| MLD'G-WINDSHIELD - BLACK |
863AA3:
| CAR NAME - HYUNDAI COUPE |
863CA2:
| GRADE - GLS |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8643A1:
| SHIPPING HOOK |
8649B6:
| ID PLATE - GEN+MES TYPE(ID) |
8651D1:
| TYPE - 5 MILE |
| RR HEATED With TIMER |
8722A3:
| H.M.S.L - RR P/TRAY |
8762C4:
8763C7:
| COLOR - BODY COLOR |
877AA2:
| FENDER GARNISH - CHROME |
8772B1:
| MLD'G-S/SILL - BODY COLOR |
8777A1:
| MLD'G-ROOF - BLACK |
8821A1:
| HEAD REST - UP/DOWN |
| SLIDING |
| DOUBLE RECLIN'G |
8825A2:
| ADJUSTER - HEIGHT ADJUSTER |
8836A3:
| SEAT BACK PNL(WithPOCKET) |
8846A1:
| RECLINER MEMORY |
885DA1:
| SLIDING |
885EA2:
| DOUBLE RECLIN'G |
885HA1:
| RECLINER MEMORY |
8854A1:
886BA1:
8866A1:
| LOAD LIMITER |
888FA1:
| BUCKLE SENSOR |
888KA2:
888NA1:
| BUCKLE SENSOR |
888RA2:
| DRIVER'S SIDE - ELR |
| LOAD LIMITER |
8912K5:
| FOR 2 PEOPLE - 5:5 SPLIT FOLD'G |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
8981A4:
| SIDE - ELR |
921BA1:
| LEVELING DEVICE - MANUAL |
9221C1:
| CONVENTIONAL - PROJECTION |
9222A1:
| RR - CONVENTIONAL |
9232A1:
9241A1:
| CLEAR |
928HA1:
| FR - LAMP |
928QA1:
| OVERHEAD CONSOLE LAMP |
| LUGGAGE LAMP |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
| LOW FUEL |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
94E5A1:
| A.B.S |
| A/BAG |
| IMMOBILIZER |
94M0A1:
| SPEEDOMETER TYPE - KMPH |
94N0A1:
| TEMPERATURE UNIT - C |
940AA1:
| TRIP ODOMETER - NORMAL |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
| SPEEDOMETER |
941AA1:
| TORQUE METER |
941BA2:
| VOLT GAUGE |
941CA3:
| FUEL CONSUMPTION |
| TYPE - DIGITAL |
| IMMOBILIZER |
9545A3:
9611A2:
| BLANK'G COVER - GERMANY TYPE |
9614A2:
| COMPONENT 1 DIN - With TRAY |
9615A3:
963GA1:
963MA1:
| TYPE - SEPARATED TYPE |
9661B1:
| DUAL HORN - DISK TYPE |
| FUNCTION - AIR FILTER |
9721A2:
| CABLE TYPE - ROTARY TYPE |
9741A1:
979AA1:
| HVAC SOURCE - HCC |
| FR WIPER-2 SPEED |
981BA1:
| FR WIPER-TIME ADJUSTER |
9811A3:
| FR WIPER - AUTOMATIC INTERVAL CONTROL |
9871A1:
3281A3:
| PEDAL TYPE - METAL PAD |
5291VA:
| AL WHEEL 7.0J * 17 - A TYPE |
5293G1:
| 215 TIRE - 215/45 R17 |
5895A1:
| BAS(BRAKE ASSISTANT SYSTEM) |
8238A5:
| GRIP HANDLE - CR COAT'G |
824GB1:
| P/WINDOW SW DR'S - METAL GRAIN |
824PB1:
| P/WINDOW SW PA'S - METAL GRAIN |
824RB1:
| P/WINDOW SW RR SIDE - METAL GRAIN |
842BA1:
| FOOT REST - METAL |
8481A2:
| GRAIN - METAL GRAIN |
8811E2:
| PURE LEATHER |
8828A1:
| LUMBAR SUPPORT - MANUAL |
8838A1:
| SEAT WARMER(HEATER) |
8873A1:
| SEAT WARMER |
| E.S.P |
94J0A1:
| E.S.P OFF |
9621E1:
| GLASS ANTENNA - RADIO |
9641A1:
972BA1:
| AIR QUALITY CONTROL SYSTEM |
9761A3:
