WT 3:
| TEMPERATE ZONE |
2191A2:
| ROLL MTG SYSTEM - SEMI ACTIVE |
2841B3:
2843A2:
| EVAP. GAS CONTROL - EURO-3 |
2861B3:
2911A1:
| UNDER COVER - With NOISE PAD |
2921A2:
| ENGINE COVER - SEMI |
3111D4:
| FUEL TANK-CAPACITY - 75 LITER |
| BATTERY SAVER |
3711A9:
3921A1:
3921A2:
4509A3:
| GATE TYPE H-MATIC |
4731A4:
| T/F TYPE - ELECTRONIC ON-DEMAND TYPE |
4951C4:
| LH/RH - BJ100+TJ100 |
529AB1:
| TIRE PRESSURE LABEL - EUROPE |
529TA7:
| TOOL SET & JACK LABEL - EUROPE |
5294A1:
| TIRE SOURCE - HAN KOOK |
| S/ABSORBER TYPE - GAS |
5414A1:
| STABILIZER BAR |
5511B1:
| RR SUSP TYPE - MULTI LINK-NORMAL |
569BA1:
| PASS'S - GERMAN LANGUAGE |
569CA1:
| FR IMPACT SENSOR |
569EA1:
| PAB ON/OFF SWITCH |
5691A3:
| DRIVER SIDE - DEPOWERED |
5692A3:
5693A1:
| CURTAIN A/BAG |
5711A2:
| HPS(HYDRAULIC POWER STRG) |
5811A6:
| FR BRAKE - DISC-17 INCH |
5812A9:
| RR BRAKE - DISC-16 INCH |
| ABS (ANTI LOCK BRK SYS) |
5911B3:
| TANDEM BOOSTER - 9+10 INCH |
5971A2:
| PARKG BRK CONTROL - FOOT TYPE |
811AA1:
| HOOD INSULATOR |
8112A2:
813DA1:
| IGN KEY REMINDER |
813MA1:
| SECURITY INDICATE |
8131A2:
8135A2:
8136A1:
| CHILD SAFETY RR DR LOCK'G |
8152A4:
817AB3:
| TAIL GATE FINISH'G-FORMED TYPE(PLASTIC) |
817BA1:
| WINDOW TRIM |
8177A1:
8178A1:
| T/GATE KEY CENTRAL DR LOCK |
| KEYLESS ENTRY-B/ALARM |
8195A1:
82A5A1:
82A7A1:
| MAP POCKET-RR DR |
82A8A1:
| LWR TRIM (MAIN TRIM)PLASTIC(NO COVERG) |
822AA1:
| DR BLACK OUT MATERIAL - TAPE |
| DR FRAME MLDG - BLACK |
823UA9:
| UPR GARNISH - FLIM INSERT |
8231B1:
| FORMED TYPE - STD |
8236A1:
| ARM REST COVER'G - PVC |
| FR DR GLASS - TINTED |
8262A3:
| LEVER FINISH'G - METAL PAINT |
834AA1:
| AUTO DOWN |
8341A2:
| POWER WINDOW(FR+RR) |
8346A1:
| TIME LAG POWER WINDOW |
8349A1:
| SW ILLUMINATION(ALL) |
84F4A1:
| CENTER UPR TRAY |
8421E2:
| T/C PILE - CARPET_DLX |
8441A3:
| FR - ASH TRAY With ILLUM |
845BA1:
| With ILLUM |
8451A2:
| With LOCK |
8452A2:
| With DAMPER |
846BA1:
846FA1:
| STORAGE BOX - With FLOCK'G |
846HA1:
| ACCESSORY TRAY - Without ILLUM. |
8462A2:
| CUP HOLDER - FR(With ILLUMINATED) |
8464A1:
| RR POWER OUTLET |
8467A1:
| POWER OUTLET |
8481A8:
| GRAIN - INSERT FILM |
85ABA1:
| CUP HOLDER |
8511A1:
| STD TYPE |
| TICKET HOLDER |
| VANITY MIRROR COVER |
852DA1:
| ILLUMINATED |
852EA1:
| TYPE - EXTENSION |
852GA2:
| VANITY MIRROR - NON GLASS TYPE |
852KA1:
| ILLUMINATED |
852LA1:
| TYPE - EXTENSION |
8521A3:
| MATERIAL - CLOTH(STD) |
8522A2:
8523A3:
853AA2:
| RR - 2 EA |
853JA1:
| RR - 1 EA |
8531A3:
8532A1:
| FR - 1 EA |
857GA1:
| LUGGAGE SIDE RH |
857HA1:
| LUGGAGE UNDER FLOOR BOX |
8571B1:
| LUGGAGE SIDE - PLASTIC |
| LUGGAGE NET HOOK |
8579A1:
| LUGGAGE NET |
858AA1:
| A PILLAR - STD |
858BA1:
| B PILLAR - STD |
858CA1:
| C PILLAR - STD |
858EA1:
| D PILLAR - STD |
| MLD'G-WINDSHIELD - BLACK |
863CA2:
| GRADE - GLS |
8631A3:
| A' TYPE - CR COAT'G |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8648A1:
| ANTI-CORROSION TREATMENT |
8649B3:
| ID PLATE - ENGLAND TYPE |
8651F1:
| TYPE - EC 2.5 MILE |
8652D2:
| COLOR - TWO TONE NATURAL |
| RR HEATED With TIMER |
8711A1:
| MLD'G-BACK LITE - BLACK |
8731B1:
| MLD'G - BODY COLOR |
| COLOR - BODY COLOR |
8772A1:
| MLD'G-S/SILL - BLACK |
8775A1:
| GARNISH-SIDE - BLACK |
8801A1:
| FR FLAT TYPE - FR FULL FLAT |
8821A3:
| SLIDING |
| DOUBLE RECLIN'G |
8825A4:
| ADJUSTER - PUMP'G DEVICE |
8836A1:
| SEAT BACK POCKET |
8838A1:
| SEAT WARMER(HEATER) |
885DA1:
| SLIDING |
885EA2:
| DOUBLE RECLIN'G |
8854A3:
886BA1:
8873A1:
| SEAT WARMER |
888DA1:
| SEAT BELT REMINDER |
| LOAD LIMITER |
888KA2:
888RA2:
| DRIVER'S SIDE - ELR |
| PASSENGER'S SIDE - ELR |
8885A2:
| LOAD LIMITER |
89F1A1:
| With CUP HOLDER |
8912D4:
| 6:4 SPLIT BACK FOLD'G - CUSHION+BACK |
8913A1:
| LH |
8914A1:
| RH |
8915A1:
| CTR |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
892VA1:
| RR LUGGAGE FULL FLAT |
8922A2:
| DOUBLE RECLIN'G |
8924A1:
| DOUBLE FOLD'G |
8931B2:
| FOR 2 PEOPLE - 5:5 SPLIT FOLD'G DOWN |
8934C3:
| UP/DOWN - UP/DOWN(LH/RH) |
8981A4:
| SIDE - ELR |
8982A4:
| CTR - ELR |
8983A4:
| SIDE - ELR |
921BA1:
| LEVELING DEVICE - MANUAL |
9221A2:
| CONVENTIONAL - CLEAR LENS |
9222A1:
| RR - CONVENTIONAL |
9231A1:
| SEPARATED - CLEAR LENS |
9232A1:
9241A1:
| CLEAR |
928FA1:
| CTR - GLOW LAMP |
928HA1:
| FR - LAMP |
928LA1:
| CARGO LAMP |
928WA2:
| BULB TYPE - 2 BULB |
9282A1:
| FR - With SUNGLASSES |
9295A1:
| O/HEAD CONSOLE TYPE - STANDARD |
94C1A1:
| A/T POSITION INDICATOR |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| PARK'G BRAKE |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
| LOW FUEL |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
94E5A1:
| A.B.S |
| A/BAG |
94E7A1:
| A/BAG OFF INDICATOR |
94G0A1:
| WASHER FLUID WARN'G LAMP |
94H2A1:
| WATER SEPARATER |
| IMMOBILIZER |
94H8A1:
| ENG OIL LEVEL |
94M0A1:
| SPEEDOMETER TYPE - KMPH |
94N0A1:
| TEMPERATURE UNIT - C |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
940EA1:
| LCD ODO/TRIP METER |
940JA1:
| 4WD LOCKING |
940KA1:
| 4WD |
| SPEEDOMETER |
| TYPE - DIGITAL |
| IMMOBILIZER |
9545A3:
9615A3:
9621K1:
| ANTENNA TELESCOPIC - ANTENNA MICRO |
963ZA1:
9661B1:
| DUAL HORN - DISK TYPE |
9686A1:
| PARK'G BRAKE WARN'G |
9711A2:
| BLOWER - 4 SPEED FAN |
| FUNCTION - AIR FILTER |
972LA1:
| FINISH - PAINT |
974BA1:
| B-PILLAR VENT |
| FR WIPER-2 SPEED |
9852A1:
| FUNCTION - WASHER FLUID LEVEL SENSOR |
9871A1:
4371B3:
| AT KNOB - LEATHER WRAPPED |
5291XA:
| AL WHEEL 7.0J * 18 - A TYPE |
5293J5:
| 235 TIRE - 235/60 R18 |
5297A3:
| FULL SIZE 1EA - AL WHEEL & TIRE |
5552A1:
| SELF LEVELIZER |
5611C3:
| 4-SPOKE - LEATHER |
5631A5:
| STEER'G COLUMN-MANUAL UPR TILT & TELES |
5895A1:
| BAS(BRAKE ASSISTANT SYSTEM) |
8176A3:
| TAIL GATE O/SIDE HANDLE - CR COAT'G |
8233G1:
8245A5:
| RR DR GLASS - PRIVACY |
8261A4:
| FINISH'G - CR COAT'G |
846LA3:
8573A3:
| FLOOR - N/PUNCH |
858RA2:
| DR SCUFF - DLX |
86A1A1:
| With WIPER DEICER |
8672A1:
| ROOF RACK |
8681A1:
| MUD GUARD-FR |
8682A1:
| MUD GUARD-RR |
8712C1:
| BACK LITE GLASS TYPE -PRIVACY |
8721B1:
| RR SPOILER With HMSL - A TYPE |
876MA1:
| ELECTRIC FOLD'G CONTROL |
8762C4:
8763C7:
8791C1:
| RR QTR GLASS TYPE -PRIVACY |
8811E2:
| PURE LEATHER |
| ACTIVE HEAD RESTRAINT |
8827A1:
| POWER SEAT |
8828A2:
| LUMBAR SUPPORT - ELECTRIC |
9219A1:
| AUTO LIGHT CONTROL |
928SA1:
| MAP LAMP-RR |
94F3A1:
| CRUISE CONTROL |
| E.S.P |
94J0A1:
| E.S.P OFF |
9571A3:
9611A3:
| BLANK'G COVER - AV 2 DIN TYPE |
963MA1:
9641A1:
| TYPE - SEPARATED TYPE |
967AA1:
| AUDIO REMO. |
967BA1:
| ACC REMO. |
972BA1:
| AIR QUALITY CONTROL SYSTEM |
9721F1:
| ELEC TYPE - FATC TYPE |
974DA1:
| 3RD VENT |
9741A2:
| RR HEATING DUCTS - 2ND & 3RD SEAT |
9761A6:
| FR COOLER - DUAL FULL AUTO A/CON |
9791A2:
| MANUAL A/CON - BUILT IN TYPE |
9815A1:
| RAIN SENSOR |
