WT 3:
| TEMPERATE ZONE |
0101A8:
| MODEL YEAR PACKAGE - 11MY |
2531A2:
| RAD CORE MATERIAL - NOT RESISTANT CACL2 |
2841B7:
| EMISSION REGULATION - EURO 5 |
2843A6:
| EVAP. GAS CONTROL - LEV-2 |
2861B3:
2865A2:
| MUFFLER MATERIAL - SUS |
2891C1:
| CATALYTIC CONVERTER - W.C.C+U.C.C TYPE |
3111C4:
| FUEL TANK-CAPACITY - 65 LITER |
| BATTERY SAVER |
3711A9:
3921A2:
4911A2:
| PROPELLAR SHAFT - TWO PIECE |
4951D9:
| LH/RH - VL3300I+VL3300I |
529AB1:
| TIRE PRESSURE LABEL - EUROPE |
5291U1:
| AL WHEEL 8.0J*19 : 8.5J*19 - A TYPE |
5293HD:
| 225 TIRE - 225/40 R19 : 245/40 R19 |
5294B4:
| TIRE SOURCE - BRIDGESTONE |
5297E1:
| AL WHEEL & TIRE (4.0T*18 T135/80R18) |
| S/ABSORBER TYPE - GAS |
5416A1:
| STRUT TOWER BAR |
5511B2:
| RR SUSP TYPE - MULTI LINK-SPORTY |
5531A2:
| TUN'G MODE - HARD SUSPENSION |
5631A3:
| STEER'G COLUMN-MANUAL LWR TILT |
569BD1:
| PASS'S - A LANGUAGE |
5691A3:
| DRIVER SIDE - DEPOWERED |
5692A3:
5693A3:
| SIDE AIR BAG-FR - FR(THORAX & PELVIS) |
| CURTAIN A/BAG |
5711A2:
| HPS(HYDRAULIC POWER STRG) |
581AA2:
| DISC SPEC - EUROPE TYPE |
5811A7:
| FR BRAKE - DISC-18 INCH |
5812A9:
| RR BRAKE - DISC-16 INCH |
| ABS (ANTI LOCK BRK SYS) |
5911B4:
| TANDEM BOOSTER - 7+8 INCH |
5971A1:
8112A2:
812AA1:
| T/LID EMERGENCY RELEASE |
8122A2:
8124A1:
| TRUNK LID TRIM - FULL COVER |
8125A2:
| T/LID INSIDE HANDLE - HOOK TYPE |
813AA1:
| SPEED SENS'G AUTO DR LOCK |
813MA1:
| SECURITY INDICATE |
8131A1:
| CENTRAL DR LOCK/UNLOCK - DR'S CONTROL |
8135A2:
8152A4:
| KEYLESS ENTRY-B/ALARM |
8195A2:
| IGNITION ILLUMINATED - LED TYPE |
82A5A1:
| DR FRAME MLDG - BLACK |
8231B2:
| FORMED TYPE - DLX |
8232A4:
| UPR TRIM FINISH'G - ARTIFICIAL LEATHER |
| FR DR GLASS - TINTED |
| FINISH'G - BODY COLOR |
834CA2:
| SAFETY WINDOW - FR DR |
834DB2:
| AUTO UP & DOWN - FR DR |
8341A1:
| POWER WINDOW(FR) |
8347A1:
| SW ILLUMINATION(DR) |
84L3A1:
| A/T INDICATOR |
8421E1:
| T/C PILE - CARPET_STD |
846BA1:
846LA3:
846NA1:
| POWER OUTLET |
8462A1:
85ACA1:
| TRUNK LID INR TRIM - WALL PAPER |
85APA1:
| TOOL CASE(OVM TOOL) |
| TICKET HOLDER |
| VANITY MIRROR COVER |
852DA1:
| ILLUMINATED |
852EA1:
| TYPE - EXTENSION |
852GA1:
852KA1:
| ILLUMINATED |
8521A3:
| MATERIAL - CLOTH(STD) |
8522A1:
8523A3:
853JA2:
| RR - 2 EA |
8531A3:
8561A2:
| RR P/TRAY MATERIAL - WithPAPER |
8571C1:
| LUGGAGE SIDE - WithPAPER |
8572A3:
| RR - WALL PAPER |
8573A2:
| FLOOR - WALL PAPER |
| LUGGAGE NET HOOK |
858AA5:
| A PILLAR - CLOTH |
| MLD'G-WINDSHIELD - BLACK |
863CA1:
| GRADE - GL |
8631A1:
| A' TYPE - BLACK |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8649A5:
| ID PLATE - EUROPE('E' MARK) TYPE |
8652B2:
| COLOR - BODY COLOR + CR MLDG |
| RR HEATED With TIMER |
8711A1:
| MLD'G-BACK LITE - BLACK |
876MA1:
| ELECTRIC FOLD'G CONTROL |
876NA1:
| SIDE REPEATER LAMP (O/S MRR) |
876PA1:
| MIRROR O/SIDE - EUROPE TYPE |
| COLOR - BODY COLOR |
8772B1:
| MLD'G-S/SILL - BODY COLOR |
8821A3:
| SLIDING |
| DOUBLE RECLIN'G |
8828A1:
| LUMBAR SUPPORT - MANUAL |
8854A3:
8866A1:
| LOAD LIMITER |
| DRIVER'S SIDE - ELR |
| PASSENGER'S SIDE - ELR |
8885A2:
| LOAD LIMITER |
8912L3:
| FOR 2 PEOPLE - BENCH-FOLD'G |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
8981A4:
| SIDE - ELR |
921BA1:
| LEVELING DEVICE - MANUAL |
9222A1:
| RR - CONVENTIONAL |
9245A1:
| LAMP TYPE - INTEGRATED |
928HA2:
| FR - REFLECTOR |
928WA2:
| BULB TYPE - 2 BULB |
9286A1:
| GLOVE BOX LAMP |
| LUGGAGE LAMP |
9297A1:
| With MAP LAMP |
9298A1:
| With SUNGLASS BOX |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| PARK'G BRAKE |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
| LOW FUEL |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
| A/BAG |
94G0A1:
| WASHER FLUID WARN'G LAMP |
| IMMOBILIZER |
| E.S.P |
94M0A1:
| SPEEDOMETER TYPE - KMPH |
94N0A1:
| TEMPERATURE UNIT - C |
940AA3:
| TRIP ODOMETER - LCD |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
9401C1:
| SPEEDOMETER |
| TYPE - DIGITAL |
| IMMOBILIZER |
9545A1:
961AA1:
| AUX |
9614B1:
| COMPONENT- 2 DIN |
9615A3:
9616A1:
| VOLUME KNOB TYPE - EUROPE TYPE |
9621E1:
| GLASS ANTENNA - RADIO |
963GA1:
963KA1:
965KA1:
| AUDIO DISPLAY |
9661B1:
| DUAL HORN - DISK TYPE |
9681A1:
| SEAT BELT |
9684A1:
| KEY OPERATED WARN'G |
| FUNCTION - AIR FILTER |
972DA1:
| O/SIDE TEMPERATURE GAUGE |
| FR WIPER-2 SPEED |
9817A1:
| MIST FUNCTION |
9819A1:
| BLADE TYPE - CONVENTIONAL |
0094A2:
| COLOR PACKAGE - TYPE 2 |
3281A3:
| PEDAL TYPE - METAL PAD |
4371A7:
| MT KNOB - LEATHER WRAPPED+CR COAT'G |
5272A1:
| RR AXLE FUNCTION - 2WD L.S.D |
5611B3:
| 3-SPOKE - LEATHER |
819BA1:
| KEYLESS ENTRY-PANIC |
819HA1:
| SMART KEY-FR DR |
8196A2:
| BUTTON START - BUTTON With ILLUMINATED |
8197A2:
| FOB HOLDER With ILLUMINATED |
8198A3:
| STEER'G LOCK TYPE - ESCL |
8233E1:
| CENTER TRIM - ARTIFICIAL LEATHER |
8262A2:
84CAA1:
| A/TRAY COVER |
84CRA1:
| CUP HOLDER COVER |
8441A5:
| FR - PORTABLE |
8445A1:
| CIGAR LIGHTER - Without ILLUM. |
848BA1:
| CTR FACIA PNL |
848CA1:
| CONSOLE UPR COVER |
8511C1:
| ELECTRIC CHROMIC MIRROR TYPE |
8579A1:
| LUGGAGE NET |
858RB1:
| SUS TYPE - A TYPE |
86A1A1:
| With WIPER DEICER |
8721B1:
| RR SPOILER With HMSL - A TYPE |
8762C4:
8763C4:
| DRIVER'S SIDE - ELECTRIC HTD-CONV |
8811E2:
| PURE LEATHER |
| ACTIVE HEAD RESTRAINT |
8827A1:
| POWER SEAT |
8838A1:
| SEAT WARMER(HEATER) |
8873A1:
| SEAT WARMER |
9213A2:
| DAYTIME RUNN'G LIGHT - EUROPE TYPE |
9221F1:
| SPORTY TYPE - MFR |
94F3A1:
| CRUISE CONTROL |
94G4A1:
| FOG LAMP (FR) |
9511A1:
9571A3:
961DA1:
| USB+IPOD |
9611P9:
| RADIO+CDC+MP3 - PA 760 |
963EA1:
| SPEAKER LOCATION CENTER-FR |
963TA1:
| SPEAKER - SUB WOOFER |
963VB1:
| SPEAKER BRAND - PREMIUM |
963WA2:
| EXTERNAL AMP - JBL AMP |
9641A1:
965AA1:
| DISTANCE TO EMPTY(D.T.E) |
965BA1:
965CA1:
965EA1:
| INSTANT FUEL CONSUMPTIO |
| TYPE - SEPARATED TYPE |
967AA1:
| AUDIO REMO. |
967BA1:
| ACC REMO. |
9721D1:
| ELEC TYPE - SOFT TOUCH TYPE |
9761A3:
