The VIN you entered, 1J8FF28889D129922, is invalid. However, it is very close to the one(s) listed below. If your VIN is listed below, click on it to continue.
1. 1J8FF28B89D129922 2009 JEEP/PATRIOT SPORT/2.4L I4 SFI DOHC 16V
| Model Year | 2009 |
| Make | Jeep |
| Model | Patriot |
| Body Type | 4 Door Wagon |
| Trim Level | Sport |
| Engine Type | L4, 2.4L; DOHC 16V |
| Country | UNITED STATES |
| Assy. Plant | Belvidere Assembly, IL |
| Production Seq. Number | 129922 |
| Drive Line Type | 4WD |
| GVWR Class | Class C 4,001-5,000 lb |
| Vehicle Type | Multipurpose Vehicle (MPV) |
| Vehicle Class | Small MPV |
| Brake System | Hydraulic |
| Fuel Type | Gasoline |
| Tonnage | 1/2 |
| Actual Cash Value | $11,750 USD |
| Repair Cost | $11,393 USD |
| Title State | MICHIGAN |
| Title Type | SCRAP CERTIFICATE OF TITLE |
| Odometer | 0 NOT ACTUAL |
| Primary Damage | Front end |
| VIN | 1J8FF28B89D129922 |
| Body Style | 4DR SPORT UTILITY |
| Color | WHITE |
| Engine | 2.4L 4 |
| Drive | Four by Four |
| Cylinders | 4 |
| Fuel | GAS |
| Keys | YES |
| ZDJĘCIA POJAZDU..............................
| Odometer Check Info | ALERT! Problem odometer records found for this 2009 JEEP PATRIOT SPORT.* |
| AirBag Check Info | GOOD NEWS! An Airbag Deployment has not been reported to CARFAX. |
| Carfax Records Info | IMPORTANT! The CARFAX database contains 15 important vehicle history records on this 2009 JEEP PATRIOT SPORT that may confirm a clean history or uncover potential problems. Order the CARFAX Vehicle History Report to see all the information reported on this vehicle. |
