Dekodowanie numeru VIN U5YFF23428L015168 na www.automo.pl
Nazwa dekodera: Dekoder VIN marki Kia #2
VIN decoder information
MODEL CODE: SEURPED06
MODEL: CEED (2006 -) (ED)
PERIOD OF ISSUE: 2006 -...
ENGINE CAPACITY: 1600 CC - U
ENGINE: DOHC - TCI
CODE MODIFICATION: BSS21CC55
BODY: SEDAN - 3DR 5P
FUEL: DIESEL - DIESEL
TRANSMISSION: MANUAL T / M - 5 SPEED
DATE OF PRODUCTION: 27/03/2008
CODE PLANT: A
EQUIPMENT CODE: GN48
COUNTRY CODE: C07
CODE Exterior: WD
CODE Interior: EQ
REGION: S4
STEERING WHEEL: L
Options
0091A5: ENGINE PACKAGE - VGT REGULAR ENG
2111A2: ENGINE GASKET - NON ASBESTOS
2531A2: RAD CORE MATERIAL - NOT RESISTANT CACL2
2841B6: EMISSION REGULATION - EURO 4
2861A2: MUFFLER MAIN ASSY - SINGLE-CR COAT'G
2862A1: MUFFLER TAIL TRIM - SINGLE
2921A4: ENGINE COVER - FULL
3111B3: FUEL TANK-CAPACITY - 53 LITER
371CA1: BATTERY SAVER
3711B3: BATTERY CAPACITY - 64AH (5HR)
3921A1: SENSOR-AIR FLOWER - NON SPEED DENSITY
4372A1: MANUAL T/M INDICATOR TRIM
529AA3: TIRE PRESSURE LABEL - GERMANY
5294B1: TIRE SOURCE - MICHELIN
5295A2: TIRE MATERIAL - SILICA
5297C1: TEMPORARY - STEEL WHEEL & TIRE
5411A1: FR SUSP TYPE - MACPH. W/COIL SPRING
5412A2: S/ABSORBER TYPE - GAS
5511B1: RR SUSP TYPE - MULTI LINK-NORMAL
5512A2: S/ABSORBER TYPE - GAS
5631A4: STEER'G COLUMN-MANUAL TILT & TELESCOPIC
569EA1: PAB ON/OFF SWITCH
5691A3: DRIVER SIDE - DEPOWERED
5692A3: PASSENGER SIDE - DEPOWERED
5693A1: SIDE AIR BAG-FR - FR(THORAX)
5695A1: CURTAIN A/BAG
5711A5: MDPS-DC
5811A4: FR BRAKE - DISC-15 INCH
5812A7: RR BRAKE - DISC-14 INCH
5891A2: ABS (ANTI LOCK BRK SYS)
5911A3: SINGLE BOOSTER - 10 INCH
6501A1: HIGH GRADE
811AA1: HOOD INSULATOR
813AA1: SPEED SENS'G AUTO DR LOCK
813BA1: IMPACT SENS'G AUTO DR UNLOCKG
813DA1: IGN KEY REMINDER
813MA1: SECURITY INDICATE
8131A2: CENTRAL DR LOCK/UNLOCK-DR'S & PA'S CTRL
8135A2: INSIDE HNDL OVER RIDE - DR'S & PA'S SIDE
8136A1: CHILD SAFETY RR DR LOCK'G
8152A3: FUEL FILLER DR REL TYPE - CABLE
817AB3: TAIL GATE FINISH'G-FORMED TYPE(PLASTIC)
8176A1: TAIL GATE O/SIDE HANDLE - NATURAL COLOR
8177A1: CENTRAL T/GATE LOCK/UNLOCK
819AA1: KEYLESS ENTRY-B/ALARM
8195A1: IGNITION ILLUMINATED - BULB TYPE
822AA1: DR BLACK OUT MATERIAL - TAPE
8221A1: DR FRAME MLDG - BLACK
8226A2: DR BLACK OUT FINISH - NON-BRIGHT
823UA7: UPR GARNISH - METALIC PAINT
8232A3: UPR TRIM FINISH'G - PVC
8235A1: MAP POCKET FINISH'G - W/O T/C PILE
8237A1: ARM REST HANDLE - PULL TYPE
8241A2: FR DR GLASS - TINTED
8245A2: RR DR GLASS - TINTED
8261A2: FINISH'G - BODY COLOR
834CA2: SAFETY WINDOW - FR DR
8341A1: POWER WINDOW(FR)
8349A1: SW ILLUMINATION(ALL)
84FAA1: RR(W/O ILL)
842BA1: FOOT REST - METAL
8421D4: N/PUNCH - STD
845BA1: W/ ILLUM
845DA1: GLOVE BOX-COOLING
8451A1: W/O LOCK
8452A2: W/ DAMPER
846BA2: W/ STORAGE BOX ARM REST - DLX(2 DIN)
846EA1: POWER OUTLET
8461B1: DLX - PVC
8462A1: CUP HOLDER - FR(W/O ILL)
8481A6: GRAIN - METAL PAINT
85APA1: TOOL CASE(OVM TOOL)
852AA1: TICKET HOLDER
852BA1: VANITY MIRROR COVER
852DA1: ILLUMINATED
852GA1: VANITY MIRROR - GLASS TYPE
852HA1: VANITY MIRROR COVER
852KA1: ILLUMINATED
8521A1: MATERIAL - VINYL
8522A1: VANITY MIRROR - GLASS TYPE
8523A1: MATERIAL - VINYL
853AA2: RR - 2 EA
8531A3: ROOF TRIM MATERIAL - CLOTH(STD)
8532A1: FR - 1 EA
8571C1: LUGGAGE SIDE - W/PAPER
8572A2: RR - PLASTIC
8573A2: FLOOR - WALL PAPER
8578A1: LUGGAGE NET HOOK
8591B1: COVER'G SHELF TRIM - WALL PAPER
8611B1: W/S GLASS TYPE-TINTED (W/O S/BAND)
8612A1: MLD'G-WINDSHIELD - BLACK
863CA2: GRADE - GLS
8631A1: A' TYPE - BLACK
8641A1: TOWING HOOK
8642A1: TIE DOWN HOOK(LASHING)
8643A1: SHIPPING HOOK
8651B1: TYPE - 2.5 MILE
8652B1: COLOR - BODY COLOR
871BA1: RR HEATED W/ TIMER
8711A1: MLD'G-BACK LITE - BLACK
8712B4: BACK LITE GLASS TYPE- TINTED(W/ HEATED)
8721B1: RR SPOILER W/ HMSL - A TYPE
8731B1: MLD'G - BODY COLOR
8762C4: PASS'S SIDE - ELECTRIC HTD-CONV
8763C7: DRIVER'S - ELECTRIC HTD-CONV(WIDE)
8765A2: COLOR - BODY COLOR
877BA1: RR DEFLECTOR
8791B1: RR QTR GLASS TYPE - TINTED
882BA1: ACTIVE HEAD RESTRAINT
8821A1: HEAD REST - UP/DOWN
8823A1: SLIDING
8824A2: DOUBLE RECLIN'G
8825A4: ADJUSTER - PUMP'G DEVICE
8828A1: LUMBAR SUPPORT - MANUAL LUMBER SUPPORT
8832A1: WALK IN DEVICE - WALK IN DEVICE
8836A1: SEAT BACK POCKET
8846A1: RECLINER MEMORY
885CA1: ACTIVE HEAD RESTRAINT
885DA1: SLIDING
885EA2: DOUBLE RECLIN'G
885HA1: RECLINER MEMORY
8854A1: HEAD REST - UP/DOWN
886BA1: SEAT BACK - SEAT BACK POCKET
8863A1: LUMBAR SUPPORT
8866A1: WALK IN DEVICE - WALK IN DEVICE
888AA1: PRE TENSIONER - MECHANICAL TYPE
888DA1: SEAT BELT REMINDER
888EA1: LOAD LIMITER
888GA1: BUCKLE PRE TENSIONER
888KA2: S/BELT ANCHOR - ADJUSTABLE
888PA1: BUCKLE PRE TENSIONER
888RA2: S/BELT ANCHOR - ADJUSTABLE
8881B1: DRIVER'S SIDE - ELR
8884D1: PASSENGER'S SIDE - ELR
8885A1: RETRACTOR PRETENSIONER - MECHANICAL TYPE
8889A1: SEAT BELT REMINDER
889MA1: LOAD LIMITER
8912D1: 6:4 SPLIT BACK FOLD'G - BACK
8913A1: LH
8914A1: RH
8915A1: CTR
892DA1: HOLDER - UPR ANCHOR
892GA1: LWR ANCHOR
898JA1: S/BELT REMINDER
8981A4: SIDE - ELR
8982A4: CTR - ELR
9119A2: JUNCTION BOX LABEL - ENGLISH LANGUAGE
921BA1: LEVELING DEVICE - MANUAL
9211A1: GENERAL - CONVENTIONAL
9218A1: BEZEL - A TYPE
9221C1: CONVENTIONAL - PROJECTION
9222A1: RR - CONVENTIONAL
9232A1: CONVENTIONAL - CLEAR LENS
9241A1: CLEAR
928FA1: CTR - GLOW LAMP
928HA2: FR - REFLECTOR
9282A1: FR - W/ SUNGLASSES
9287A1: LUGGAGE LAMP
94C6A1: DIRECTION INDICATOR
94C7A1: OIL PRESSURE
94C8A1: BRAKE OIL
94C9A1: PARK'G BRAKE
94D0A1: DR AJAR - DR AJAR
94D1A1: BATTERY CHARGE
94D2A1: HIGH BEAM
94D3A1: LOW BEAM
94D4A1: LOW FUEL
94D5A1: RR FOG LAMP
94D7A1: TRUNK LID(T/GATE) OPEN
94D9A1: CHECK ENGINE
94E3A1: SEAT BELT
94E5A1: A.B.S
94E6A1: A/BAG
94G0A1: WASHER FLUID WARN'G LAMP
94G4A1: FOG LAMP (FR)
94G5A1: GLOW INDICATOR
94H2A1: WATER SEPARATER
94H6A1: IMMOBILIZER
94M0A1: SPEEDOMETER TYPE - KMPH
94N0A1: TEMPERATURE UNIT - C
940AA2: TRIP ODOMETER - ELEC.
940BA1: TACHOMETER
940CA1: FUEL
940DA1: WATER TEMP.
9402A1: SPEEDOMETER
9491A1: RHEOSTAT
9541A1: BODY CONTROL MODULE - BCM(ETACS)
9542A1: IMMOBILIZER
9545A3: FREQUENCY-SMART KEY - GENERAL
9611Z2: RADIO+CD+MP3 - H 000
9614B1: COMPONENT- 2 DIN
9615A3: FREQUENCY VIBRATION - AM9K/FM50K
9618A1: USB+AUX
9621G1: ANTENNA TELESCOPIC - ANTENNA ROOF TYPE
963CA1: SPEAKER LOCATION FR DR - GENERAL
963GA1: SPEAKER LOCKTION RR QTR - GENERAL
963MA1: SPEAKER LOCATION QUADRANT INR COVER
9651A1: TYPE - SEPARATED TYPE
9661B1: DUAL HORN - DISK TYPE
967AA1: AUDIO REMO.
9681A1: SEAT BELT
9684A1: KEY OPERATED WARN'G
9711A2: BLOWER - 4 SPEED FAN
9713A2: PTC HEATER_INT TYPE
9714A1: FUNCTION - AIR FILTER
9721A2: CABLE TYPE - ROTARY TYPE
9741A1: RR HEATING DUCTS - 2ND SEAT
981AA1: FR WIPER-2 SPEED
981BA1: FR WIPER-TIME ADJUSTER
9811A2: FR WIPER - INTERMITTENT(VARIABLE)
9817A1: MIST FUNCTION
9852A1: FUNCTION - WASHER FLUID LEVEL SENSOR
9871A1: RR WIPER - INTERMITTENT(NON VARIABLE)
0093C1: VEHICLE PACKAGE - SPORTS
2891F1: CATALYTIC CONVERTER - D.P.F
3281A2: PEDAL TYPE - AL PAD
4371A3: MT KNOB - LEATHER WRAPPED
5291VB: AL WHEEL 7.0J * 17 - B TYPE
5293HA: 225 TIRE - 225/45 R17
5611B3: 3-SPOKE - LEATHER
5894A1: ESC (ELECTRONIC STABILITY CONTROL)
5972A2: P/BRAKE KNOB TRIM - LEATHER WRAPPED
5973A3: P/BRAKE PUSH BUTTON TRIM - CR COAT'G
8161C2: SINGLE TILT'G & SLID'G - POWER-NORMAL
8194B3: TYPE - FOLDING
8242A1: HYDROPHOBIC GLASS
8246A1: HYDROPHOBIC GLASS-RR
8262A2: LEVER FINISH'G - CR COAT'G
8431A1: CAR MAT - T/C PILE, STD
8441A3: FR - ASH TRAY W/ ILLUM
8445A2: CIGAR LIGHTER - W/ ILLUM
846LA2: CONSOLE COVER - LEATHER
8511C1: ELECTRIC CHROMIC MIRROR TYPE
857HA1: LUGGAGE UNDER FLOOR BOX
8579A1: LUGGAGE NET
858RC1: SUS TYPE - W/ETCHING
86A1A1: W/ WIPER DEICER
8631B1: B TYPE - BLACK
876DA1: BLUE GLASS
876MA1: ELECTRIC FOLD'G CONTROL
8811B3: CLOTH - L/CLOTH(CLOTH+LEATHER)
8838A1: SEAT WARMER(HEATER)
8873A1: SEAT WARMER
921JA1: ESCORT
9299A1: W/ SUNROOF SW
94H9A1: E.S.P
9511A1: AUTO LIGHT CONTROL SYSTEM - 1 STAGE
9571A3: RR PARK'G ASSIST SYSTEM(RPAS)
961DA1: USB+IPOD
9641A1: AUTO CRUISE CONTROL - CONVENTIONAL
967BA1: ACC REMO.
9761A3: FR COOLER - FULL AUTO A/CON
9815A1: RAIN SENSOR
