WT 2:
| COLD ZONE |
2111A2:
2531A2:
| RAD CORE MATERIAL - NOT RESISTANT CACL2 |
2841B6:
| EMISSION REGULATION - EURO 4 |
2861A2:
| MUFFLER MAIN ASSY - SINGLE-CR COAT"G |
2891B1:
| CATALYTIC CONVERTER - U.C.C TYPE |
2921A4:
| ENGINE COVER - FULL |
3111B3:
| FUEL TANK-CAPACITY - 53 LITER |
| BATTERY SAVER |
3711B3:
| BATTERY CAPACITY - 64AH (5HR) |
3921A1:
4371A1:
| MT KNOB - SOFT PVC |
529AB1:
| TIRE PRESSURE LABEL - EUROPE |
5291B5:
| STEEL WHEEL - 5.5J * 15 |
5294B1:
| TIRE SOURCE - MICHELIN |
5295A2:
| TIRE MATERIAL - SILICA |
5296C1:
| FULL SIZE WHL COVER - A TYPE |
5297C1:
| TEMPORARY - STEEL WHEEL & TIRE |
| S/ABSORBER TYPE - GAS |
5511B1:
| RR SUSP TYPE - MULTI LINK-NORMAL |
5611B2:
| 3-SPOKE - POLY URETHANE |
5631A4:
| STEER"G COLUMN-MANUAL TILT & TELESCOPIC |
569BB9:
| PASS"S - POLAND LANGUAGE |
569EA1:
| PAB ON/OFF SWITCH |
5691A3:
| DRIVER SIDE - DEPOWERED |
5692A3:
5693A1:
| CURTAIN A/BAG |
5711A5:
| MDPS-DC |
5811A4:
| FR BRAKE - DISC-15 INCH |
5812A7:
| RR BRAKE - DISC-14 INCH |
| ABS (ANTI LOCK BRK SYS) |
5911A3:
| SINGLE BOOSTER - 10 INCH |
811AA1:
| HOOD INSULATOR |
813AA1:
| SPEED SENS"G AUTO DR LOCK |
| IMPACT SENS"G AUTO DR UNLOCKG |
813DA1:
| IGN KEY REMINDER |
8131A2:
| CENTRAL DR LOCK/UNLOCK-DR"S & PA"S CTRL |
8135A2:
| INSIDE HNDL OVER RIDE - DR"S & PA"S SIDE |
8136A1:
| CHILD SAFETY RR DR LOCK"G |
8152A3:
817AB3:
| TAIL GATE FINISH"G-FORMED TYPE(PLASTIC) |
8176A1:
| TAIL GATE O/SIDE HANDLE - NATURAL COLOR |
8177A1:
822AA1:
| DR BLACK OUT MATERIAL - TAPE |
| DR FRAME MLDG - BLACK |
8226A2:
| DR BLACK OUT FINISH - NON-BRIGHT |
8232A3:
| UPR TRIM FINISH"G - PVC |
8235A1:
| MAP POCKET FINISH"G - Without T/C PILE |
8237A1:
| ARM REST HANDLE - PULL TYPE |
| FR DR GLASS - TINTED |
8245A2:
| RR DR GLASS - TINTED |
8261A1:
| FINISH"G - BLACK COLOR |
8341A1:
| POWER WINDOW(FR) |
8349A1:
| SW ILLUMINATION(ALL) |
842BA1:
| FOOT REST - METAL |
8421D4:
| N/PUNCH - STD |
845BA1:
| With ILLUM |
8451A1:
| Without LOCK |
8452A2:
| With DAMPER |
846EA1:
| POWER OUTLET |
8462A1:
85APA1:
| TOOL CASE(OVM TOOL) |
8511B1:
| DAY/NIGHT TYPE |
| TICKET HOLDER |
| VANITY MIRROR COVER |
852GA1:
8521A1:
| MATERIAL - VINYL |
8522A1:
8523A1:
| MATERIAL - VINYL |
853AA2:
| RR - 2 EA |
853JA1:
| RR - 1 EA |
8531A3:
8532A1:
| FR - 1 EA |
8571C1:
| LUGGAGE SIDE - WithPAPER |
8572A2:
| RR - PLASTIC |
8573A2:
| FLOOR - WALL PAPER |
8591B1:
| COVER"G SHELF TRIM - WALL PAPER |
8611B1:
| WithS GLASS TYPE-TINTED (Without S/BAND) |
| MLD"G-WINDSHIELD - BLACK |
863CA1:
| GRADE - GL |
8631A1:
| A" TYPE - BLACK |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8643A1:
| SHIPPING HOOK |
8651B1:
| TYPE - 2.5 MILE |
8652B1:
| COLOR - BODY COLOR |
8681A1:
| MUD GUARD-FR |
8682A1:
| MUD GUARD-RR |
| RR HEATED With TIMER |
8711A1:
| MLD"G-BACK LITE - BLACK |
| BACK LITE GLASS TYPE- TINTED(With HEATED) |
8722A4:
| H.M.S.L - T/GATE OTR |
8731B1:
| MLD"G - BODY COLOR |
877BA1:
| RR DEFLECTOR |
8791B1:
| RR QTR GLASS TYPE - TINTED |
8811C1:
| CLOTH - CLOTH |
8821A1:
| HEAD REST - UP/DOWN |
| SLIDING |
| DOUBLE RECLIN"G |
885DA1:
| SLIDING |
885EA2:
| DOUBLE RECLIN"G |
8854A1:
888AA1:
| PRE TENSIONER - MECHANICAL TYPE |
888DA1:
| SEAT BELT REMINDER |
| LOAD LIMITER |
888GA1:
| BUCKLE PRE TENSIONER |
888KA2:
888PA1:
888RA2:
| DRIVER"S SIDE - ELR |
| PASSENGER"S SIDE - ELR |
8885A1:
| RETRACTOR PRETENSIONER - MECHANICAL TYPE |
8889A1:
| LOAD LIMITER |
8912D4:
| 6:4 SPLIT BACK FOLD"G - CUSHION+BACK |
8913A1:
| LH |
8914A1:
| RH |
8915A1:
| CTR |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
898JA1:
| S/BELT REMINDER |
8981A4:
| SIDE - ELR |
8982A4:
| CTR - ELR |
9119A2:
| JUNCTION BOX LABEL - ENGLISH LANGUAGE |
921BA1:
| LEVELING DEVICE - MANUAL |
9211A1:
| GENERAL - CONVENTIONAL |
9213A2:
| DAYTIME RUNN"G LIGHT - EUROPE TYPE |
9222A1:
| RR - CONVENTIONAL |
9232A1:
| CONVENTIONAL - CLEAR LENS |
9241A1:
| CLEAR |
928FA1:
| CTR - GLOW LAMP |
928HA2:
| FR - REFLECTOR |
| LUGGAGE LAMP |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| PARK"G BRAKE |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
94D3A1:
| LOW BEAM |
| LOW FUEL |
94D5A1:
| RR FOG LAMP |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
94E5A1:
| A.B.S |
| A/BAG |
94G4A1:
| FOG LAMP (FR) |
94G5A1:
| GLOW INDICATOR |
94H2A1:
| WATER SEPARATER |
| IMMOBILIZER |
94M0A1:
| SPEEDOMETER TYPE - KMPH |
94N0A1:
| TEMPERATURE UNIT - C |
940AA2:
| TRIP ODOMETER - ELEC. |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
| SPEEDOMETER |
| IMMOBILIZER |
9545A3:
9611Z2:
| RADIO+CD+MP3 - H 000 |
9614B1:
| COMPONENT- 2 DIN |
9615A3:
9621G1:
| ANTENNA TELESCOPIC - ANTENNA ROOF TYPE |
963ZA1:
| TYPE - SEPARATED TYPE |
9661A1:
| HORN - SINGLE |
967AA1:
| AUDIO REMO. |
9681A1:
| SEAT BELT |
9684A1:
| KEY OPERATED WARN"G |
9711A2:
| BLOWER - 4 SPEED FAN |
9713A2:
| PTC HEATER_INT TYPE |
| FUNCTION - AIR FILTER |
9721A2:
| CABLE TYPE - ROTARY TYPE |
9741A1:
| FR WIPER-2 SPEED |
981BA1:
| FR WIPER-TIME ADJUSTER |
9817A1:
| MIST FUNCTION |
9871A1:
0091A6:
| ENGINE PACKAGE - VGT LOW POWER ENG |
0094A2:
| COLOR PACKAGE - TYPE 2 |
5293EH:
| 195 TIRE - 195/65 R15 |
813MA1:
| SECURITY INDICATE |
| KEYLESS ENTRY-B/ALARM |
8194B3:
| TYPE - FOLDING |
834CA2:
| SAFETY WINDOW - FR DR |
84FAA1:
| RR(Without ILL) |
8441A3:
| FR - ASH TRAY With ILLUM |
8445A2:
| CIGAR LIGHTER - With ILLUM |
845DA1:
| GLOVE BOX-COOLING |
846BA2:
| With STORAGE BOX ARM REST - DLX(2 DIN) |
8461B1:
| DLX - PVC |
8762C4:
| PASS"S SIDE - ELECTRIC HTD-CONV |
8763C7:
| DRIVER"S - ELECTRIC HTD-CONV(WIDE) |
| ACTIVE HEAD RESTRAINT |
8825A4:
| ADJUSTER - PUMP"G DEVICE |
8828A1:
| LUMBAR SUPPORT - MANUAL LUMBER SUPPORT |
8863A1:
| LUMBAR SUPPORT |
9282A1:
| FR - With SUNGLASSES |
963MA1:
9761A1:
| FR COOLER - MANUAL A/CON |
