WT 2:
| COLD ZONE |
2111A2:
2841B7:
| EMISSION REGULATION - EURO 5 |
2845A2:
| O.B.D(ON-BOARD DIAGNOSTICS) - E.O.B.D |
2861A1:
| MUFFLER MAIN ASSY - SINGLE-BLACK PAINT |
2911A2:
| UNDER COVER - Without NOISE PAD |
3111B7:
| FUEL TANK-CAPACITY - 58 LITER |
3113A1:
| FUEL TANK MATERIAL - STEEL |
327AA1:
| KICKDOWN MECHANISM |
| BATTERY SAVER |
3711B6:
| BATTERY CAPACITY - 72AH (5HR) |
3731A2:
| AMS - With MICOM |
3914A1:
| F.F.H.S(FUEL FILTER HEAT"G) |
4371A1:
| MT KNOB - SOFT PVC |
4501A1:
| CLUTCH LOCK |
529AB1:
| TIRE PRESSURE LABEL - EUROPE |
529TA3:
| TOOL SET & JACK LABEL - AUS+NEW ZEALAND |
5291MA:
| AL WHEEL 6.5J * 16 - A TYPE |
5293GG:
| 215 TIRE - 215/70 R16 |
5295A3:
| TIRE MATERIAL - LRR |
5297D1:
| TEMPORARY - TIRE MOBILITY KIT (TMK) |
| S/ABSORBER TYPE - GAS |
5511B1:
| RR SUSP TYPE - MULTI LINK-NORMAL |
5611C2:
| 4-SPOKE - POLY URETHANE |
569BD2:
| PASS"S - B LANGUAGE |
569CA1:
| FR IMPACT SENSOR |
569EA1:
| PAB ON/OFF SWITCH |
569JA1:
| PAB ON/OFF LAMP |
5691A3:
| DRIVER SIDE - DEPOWERED |
5692A3:
5711A6:
| MDPS |
5811A5:
| FR BRAKE - DISC-16 INCH |
5812A7:
| RR BRAKE - DISC-14 INCH |
| ABS (ANTI LOCK BRK SYS) |
5895A1:
| BAS(BRAKE ASSISTANT SYSTEM) |
5896A1:
| ESS (EMERGENCY STOP SIGNAL) |
5911A6:
| SINGLE BOOSTER - 11 INCH |
5971A1:
5973A3:
| P/BRAKE PUSH BUTTON TRIM - CR COAT"G |
811AA1:
| HOOD INSULATOR |
813DA1:
| IGN KEY REMINDER |
8131A2:
| CENTRAL DR LOCK/UNLOCK-DR"S & PA"S CTRL |
8133A1:
| SW ILLUMINATION |
8135A3:
| INSIDE HNDL OVER RIDE - ALL DR |
8136A1:
| CHILD SAFETY RR DR LOCK"G |
8152A3:
817AB3:
| TAIL GATE FINISH"G-FORMED TYPE(PLASTIC) |
817BA1:
| WINDOW TRIM |
8177A1:
8195A1:
82A5A1:
82A7A1:
| MAP POCKET-RR DR |
8223A7:
| DR BELT LINE MLDG - NON- BRIGHT |
8231B1:
| FORMED TYPE - STD |
8232A6:
| UPR TRIM FINISH"G - PLASTIC (PAINT) |
8233A1:
| CENTER TRIM - PLASTIC(NO COVER"G) |
8235A1:
| MAP POCKET FINISH"G - Without T/C PILE |
8236A7:
| ARM REST COVER"G - PLASTIC |
824AA3:
| P/WINDOW DR"S - AUTO DOWN |
824BA1:
| P/WINDOW PA"S - NONE AUTO |
824CA1:
| P/WINDOW RR DR - NONE AUTO |
824FC1:
| P/WINDOW SW - ILLUMINATION(ALL) |
| FR DR GLASS - TINTED |
8245A2:
| RR DR GLASS - TINTED |
| FINISH"G - BODY COLOR |
8262A3:
| LEVER FINISH"G - METAL PAINT |
84C3A4:
| A/REST COVER - ARTIFICIAL LEATHER |
8421D1:
| N/PUNCH - FLAT TYPE |
8445A3:
| CIGAR LIGHTER - BLANK"G COVER |
845BA1:
| With ILLUM |
8452A2:
| With DAMPER |
846BA1:
846EA1:
| POWER OUTLET |
846FA2:
| STORAGE BOX - Without FLOCK"G |
8462A1:
8481A6:
| GRAIN - METAL PAINT |
8511B1:
| DAY/NIGHT TYPE |
| TICKET HOLDER |
| VANITY MIRROR COVER |
852EA1:
| TYPE - EXTENSION |
852GA1:
852LA1:
| TYPE - EXTENSION |
8521A1:
| MATERIAL - VINYL |
8522A1:
8523A1:
| MATERIAL - VINYL |
853AA2:
| RR - 2 EA |
853JA2:
| RR - 2 EA |
8531A5:
| ROOF TRIM MATERIAL - NON WOVEN |
8532A1:
| FR - 1 EA |
857FA1:
| LUGGAGE SIDE LH |
857IA1:
| LUGGAGE SCREEN |
857JA1:
| LUGGAGE CTR TRAY |
8571B1:
| LUGGAGE SIDE - PLASTIC |
8573A3:
| FLOOR - N/PUNCH |
8575A3:
| SEAT BACK - N/PUNCH |
| LUGGAGE NET HOOK |
858AA1:
| A PILLAR - STD |
858BA1:
| B PILLAR - STD |
858CA1:
| C PILLAR - STD |
858EA1:
| D PILLAR - STD |
858RA1:
| DR SCUFF - STD |
858SA1:
| STEP PLATE |
| MLD"G-WINDSHIELD - BLACK |
863CA1:
| GRADE - GL |
8631A9:
| A TYPE - SILVER PAINT |
| TOWING HOOK |
| TIE DOWN HOOK(LASHING) |
8648A1:
| ANTI-CORROSION TREATMENT |
8649B6:
| ID PLATE - GEN+MES TYPE(ID) |
8651B1:
| TYPE - 2.5 MILE |
8652B1:
| COLOR - BODY COLOR |
8681A1:
| MUD GUARD-FR |
8682A1:
| MUD GUARD-RR |
| RR HEATED With TIMER |
| BACK LITE GLASS TYPE- TINTED(With HEATED) |
8721A1:
| RR SPOILER - Without HMSL |
8722A2:
| H.M.S.L - T/GATE INR |
8723A1:
| LENS TYPE - NON LED |
8725A1:
| MLD"G-ROOF - BLACK |
8731A1:
| MLD"G - BLACK |
877BA1:
| RR DEFLECTOR |
877FA1:
| WHL ARCH MLDG |
8772B2:
| MLD"G-S/SILL - NATURAL COLOR |
8791B1:
| RR QTR GLASS TYPE - TINTED |
8811C1:
| CLOTH - CLOTH |
| SLIDING |
| DOUBLE RECLIN"G |
8825A4:
| ADJUSTER - PUMP"G DEVICE |
8836A1:
| SEAT BACK POCKET |
885DA1:
| SLIDING |
885EA2:
| DOUBLE RECLIN"G |
886BA1:
888DA1:
| SEAT BELT REMINDER |
| LOAD LIMITER |
888HA1:
| ANCHOR PRE TENSIONER |
888JA1:
| S/BELT HEIGHT ADJUSTMENT |
888SA1:
| DRIVER"S SIDE - ELR |
| PASSENGER"S SIDE - ELR |
8885A2:
8889A1:
| LOAD LIMITER |
89B1A1:
| Without BOX |
89C1A1:
| DRINK HOLDER |
8912D1:
| 6:4 SPLIT BACK FOLD"G - BACK |
8913A1:
| LH |
8914A1:
| RH |
8915A1:
| CTR |
| HOLDER - UPR ANCHOR |
| LWR ANCHOR |
8922A2:
| DOUBLE RECLIN"G |
898JA1:
| S/BELT REMINDER |
8981A4:
| SIDE - ELR |
8982A4:
| CTR - ELR |
921BA1:
| LEVELING DEVICE - MANUAL |
9213A2:
| DAYTIME RUNN"G LIGHT - EUROPE TYPE |
9222A1:
| RR - CONVENTIONAL |
9231B1:
| INTEGRATED - CLEAR LENS |
9233A1:
| TYPE - STD |
9241A1:
| CLEAR |
928FA3:
| CTR - DELAY LAMP |
928HA2:
| FR - REFLECTOR |
928WA2:
| BULB TYPE - 2 BULB |
9282A1:
| FR - With SUNGLASSES |
| LUGGAGE LAMP |
9295A1:
| O/HEAD CONSOLE TYPE - STANDARD |
9297A1:
| With MAP LAMP |
9298A1:
| With SUNGLASS BOX |
| DIRECTION INDICATOR |
| OIL PRESSURE |
| BRAKE OIL |
| PARK"G BRAKE |
| DR AJAR - DR AJAR |
| BATTERY CHARGE |
| HIGH BEAM |
94D3A1:
| LOW BEAM |
| LOW FUEL |
94D5A1:
| RR FOG LAMP |
| TRUNK LID(T/GATE) OPEN |
| CHECK ENGINE |
| SEAT BELT |
94E5A1:
| A.B.S |
| A/BAG |
94G5A1:
| GLOW INDICATOR |
94H1A1:
| BRAKE VACUUM |
94H2A1:
| WATER SEPARATER |
| IMMOBILIZER |
94H7A1:
| MDPS |
94H8A1:
| ENG OIL LEVEL |
94M0A1:
| SPEEDOMETER TYPE - KMPH |
94N0A1:
| TEMPERATURE UNIT - C |
94X6A1:
| M/T SHIFT INDICATOR |
940AA3:
| TRIP ODOMETER - LCD |
| TACHOMETER |
| FUEL |
| WATER TEMP. |
9401C1:
| SPEEDOMETER |
| TYPE - DIGITAL |
| IMMOBILIZER |
9545A3:
9611NG:
| RADIO+CD+MP3+RDS - PA 710R |
9614B1:
| COMPONENT- 2 DIN |
9615A3:
9618A1:
| USB+AUX |
9621G1:
| ANTENNA TELESCOPIC - ANTENNA ROOF TYPE |
963KA1:
963ZA1:
965AA1:
| DISTANCE TO EMPTY(D.T.E) |
965BA1:
965CA1:
965DA1:
| ELAPSE TIME(E/T) |
965EA1:
| INSTANT FUEL CONSUMPTIO |
9661A1:
| HORN - SINGLE |
9681A1:
| SEAT BELT |
9713A2:
| PTC HEATER_INT TYPE |
| FUNCTION - AIR FILTER |
972DA1:
| O/SIDE TEMPERATURE GAUGE |
9721B1:
| ELEC TYPE - ROTARY TYPE |
9741A1:
9761A1:
| FR COOLER - MANUAL A/CON |
| FR WIPER-2 SPEED |
9819A2:
| BLADE TYPE - AERO |
9871A1:
5631A4:
| STEER"G COLUMN-MANUAL TILT & TELESCOPIC |
569HA1:
| ROLLOVER SENSOR |
5693A1:
| CURTAIN A/BAG |
589AA1:
| DBC (DOWNHILL BRAKE CONTROL) |
589GA1:
| VSM (VEHICLE STABILITY MANAGEMENT) |
589HA1:
| HAC (HILLSTART ASSIST CONTROL) |
813AA1:
| SPEED SENS"G AUTO DR LOCK |
| IMPACT SENS"G AUTO DR UNLOCKG |
| KEYLESS ENTRY-B/ALARM |
8194B3:
| TYPE - FOLDING |
8672A1:
| ROOF RACK |
8762C4:
| PASS"S SIDE - ELECTRIC HTD-CONV |
8763C4:
| DRIVER"S SIDE - ELECTRIC HTD-CONV |
| ACTIVE HEAD RESTRAINT |
8821A5:
| HEAD REST - UP/DOWN & SLIDING |
8854A5:
89E4A1:
| REMOTE FOLD"G |
921JA1:
| ESCORT |
| E.S.P |
94J0A1:
| E.S.P OFF |
94J1A1:
