VIN wydaje się ok, ale w USA nie słyszeli o tym Audi, ani w moich źródłach, ani jak sprawdzałem na stronach autocheck i carfax. Coś dziwnego. Poniżej masz zdekodowany VIN z wyposażeniem tego Audi. Z VINu wychodzi też że produkcja do wrzesień 2009, a w ogłoszeniu jest że to rocznik 2000.
Dekodowanie numeru VIN TRUZZZ8NZY1021546 na www.automo.pl
Vehicle Identification No.: TRUZZZ8NZY1021546
Model Designation: audi tt coupe 1.8 qu.
Model: ATT
Date of production: 16.09.1999
Model year: 2000
Sales type: 8N3069
Engine code: APX
Transmission code: DQB
Axle drive: 6S
Interior trim code: JN
Roof color: A2
Exterior color/Paint Code: A2/Y9B
Activated carbon canister: [1E1] : Activated carbon canister
Additional child seat anchors: [3B0] : Without additional child seat anchor
Air bag: [4UF] : Driver's and front passenger air bagwith front passenger air bagdeactivation
Anti-theft protection system: [7AA] : Electronic vehicle immobilization device
Auxiliary heating: [9M0] : Without auxiliary/parking heater
Backrest release: [3H5] : Backrest release for front seats withadditional backrest release on the innerside
Base engine: [T6B] : 4-cylinder gasoline engine 1.8 Lunit 06A.G
Batteries: [J1L] : Battery 280 A (60 Ah)
Body measures: [5C7] : Additional body measures
Body style: [K8C] : Coupe
Brake pad wear indicator: [9U0] : Without brake pad wear indicator
Brake type, front: [1LT] : Disc brakes, front
Brake type, rear: [1KF] : Disc brakes, rear
Bumper systems: [2K1] : Reinforced bumpers
CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation
CD changer/CD player: [7A2] : CD changer
Cd enhancing underbody panel: [2D1] : Complete cd enhancing underbody panel
Center armrest: [6E0] : Without center armrest front
Cruise control: [8T0] : Without cruise control system (CCS)
Cup holder: [4M0] : Without cup holder
Customized installation: [FC0] : Without customized installation
Delivery equipment: [2A4] : Delivery equipment for shipment (transitcoating) with thick seat cover
Door and lid locking system: [4K4] : Radio remote controlled central locking
Doors: [0A1] : 2 doors
Drive layout: [1X1] : Four wheel drive
Emission standard: [0GF] : Emission standard D3 EU3D
Engine specifications: [M4S] : 4-cyl. turbo gasol. eng. 1.8 L/165kW 20VEU 3Dbase engine is T6B
Equipment levels: [A8S] : Standard equipment
Exterior mirror setting: [6XD] : Exterior mirrors: electricallyadjustable/heated
Exterior noise suppression measures: [2B9] : Additional exterior noise suppression
First aid kit / warning triangle: [1T3] : First aid kit with warning triangle
Fresh air intake for passenger compartment (with particulate filter): [2V1] : Dust and pollen filter
Front license plate bracket: [6W5] : Front license plate bracket
Front stabilizer: [0AN] : Stabilizer, front
Fuel filler cap/door, locking option: [2W0] : Fuel filler cap
Fuel quantity for initial filling: [1Z2] : Increase in initial standard fuelfilling
Fuel systems: [0F2] : Fuel system for carburetor gasolineengine
Fuel tank treatment: [2LB] : Fuel tank with special materialtreatment
Gearshift boot/cover: [6R3] : Rubber gearshift boot
Gearshift knob/handle: [6Q7] : Leather gearshift knob with aluminumappearance
General operating permit, alterations: [C03] : Operating permit, alteration
Generators: [8GL] : Alternator 120 A
Hand brake lever handle: [6PA] : Plastic hand brake lever handle
Handling standard production and pre-production series: [FA0] : Control of standard production
Hardtop: [5F0] : Without hardtop
Headlight: [8JG] : Headlight with gas discharge lamp fordriving on the right
Headlight washer system: [8X1] : Headlight washer system
Headlight-range adjustment: [8Q2] : Automatic headlight-range adjustmentstatic
Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating
Heated washer nozzles: [9T1] : Heated washer nozzles, front
Heating and air conditioning system: [9AK] : Climatronic with impact pressurecontrol free of cfc
Horns: [8Y1] : Two-tone horn
Insert for the filling up of unleaded fuel/fuel type: [2G9] : Filler neck module 2 with insert
Instrument inserts: [U1A] : Instrument insert with km/h speedometer,clock, tachometer and trip odometer
Label for central electric: [0W1] : Label for central electricGerman-speaking countries
Label for radio remote control: [7CA] : Without label for radio remote control
Left vanity mirror: [4SD] : Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid: [4E6] : Sensor-controlled luggage compartmentopening
Lockable wheel bolts: [1PC] : Wheel bolts with anti-theft protection(unlockable)
Lumbar support: [7P0] : Without lumbar supportin seat backrests
Mud flap: [6N0] : Without mud flaps
Multi-function display/trip computer: [9Q2] : Multi-function display/on-board computerwith check control
Outdoor temperature gage: [9Y1] : Outdoor temperature gage
Owner's manuals: [0VC] : Information kit in German
Paint preservative/transit coating: [5K5] : Transit coating film with additionaltransport protection measures
Park distance control: [7X0] : Without park distance control
Platform module floor pan, rear: [4P0] : Rear floor panel module, type 1
Proportioning valve: [1H0] : Without proportioning valve
Radios: [8UD] : Radio "concert"
Rear axle: [0N5] : Standard rear axle
Rear stabilizer: [0BJ] : Rear stabilizer
Rear trim panel: [6V1] : Rear trim panel (ECE)
Rear window wiper and washer system: [8M0] : W/o rear window wiper and washer system
Remote-controlled garage door opener: [VC0] : W/o remote-controlled garage door opener
Right exterior mirror: [5RU] : Right exterior mirror: convex(large viewing field)
Right vanity mirror: [4TD] : Right vanity mirror illuminated
Safety certificate: [0LW] : Special plates/stickers/safety certificates for Germany
Seat covering: [N5D] : Valcona leather seat covering
Self-collection / special control: [A00] : No self-collection
Service interval prolongation: [QG0] : Without service interval prolongation
Shock absorption, chassis, front: [1GS] : Front shock absorption (AUDI TT)
Shock absorption, chassis, rear: [1JL] : Rear shock absorption
Side air bag: [4X1] : Side air bag front
Smoking/non-smoking package: [9JD] : Smoking package, ashtray front
Spare wheel/breakdown set: [1G0] : Without spare wheel
Speaker installation: [8RY] : Speakers with BOSE sound
Special labels/plates: [0ST] : Labels/plates in German and French
Start/stop system/regenerative braking: [7L0] : Without inertia benefit system/deceleration fuel cut-off/idle stopvalve
Steering: [1N4] : Power steering
Steering column systems: [2C5] : Axial and vertical adjustable steeringcolumn
Steering wheels: [2ZN] : Leather trimmed sports steering wheelwith aluminum appearance
Telephone/telematics: [9W0] : W/o car phone preparation/installation
Throttle actuation: [0L2] : Electric throttle actuation
Tires: [H6G] : Tires 225/45 ZR17 91Y
Transmission specifications: [G0L] : 6-speed manual transmission forfour-wheel drive vehicle
Transmission types/gearshift mechanisms: [0G4] : Cable gearshift
Type approval countries/countries with special requirements: [B99] : Type approval EC
Type sign: [2Z1] : Type sign at rearand "Quattro" nameplates respectively
Vehicle class differentiation units/platform components: [0CV] : Vehicle class differentiation 8N0
Washer fluid level indicator: [8W1] : Washer fluid level indicator
Weight category rear axle: [0YP] : Weight range 14installation control only, norequirement forecast
Wheels: [CC8] : Alloy wheels 5J x 15
Wind blocker: [7S0] : Without wind blocker
Window regulator: [4R1] : Power windows
Windshield glass type: [4GH] : Windshield in heat-insulating glasswith sunshield
Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds)
Front seats: [Q1D] : Sports front seats
TV reception/digital radio reception: [QV0] : W/o TV reception/digital radio reception
Control number (no PR-Family): [SA9] : Inventory control model 4
Weight category front axle: [U93] : Suspension range 192
